Flashing red led
rwigginsrwiggins Posts: 1
hello,
I’ve been getting a flashing red indicator light on my go when I plug it in to charge, however it does not appear to be charging. I read the indicator light meanings in the faq, but it doesn’t say anything about a  The flashing red light so if anyone could tell me what a red blinking light means that would be very helpful. Also I tried holding down the power button for 20 seconds and that does cause the flashing rate to momentarily change as if it’s considering doing something else but then it goes right back to flashing red.
  • OculusSupportOculusSupport Posts: 804 Oculus Staff
    Hey @rwiggins, I'm sorry to hear you're having problems with your Oculus Go. Please try using a different charger and charging cable to see if it will charge. If it still won't charge, your Go may have a hardware issue. Please contact support at https://support.oculus.com so we can help you out. Thanks! -Rick
  • JimDaystarJimDaystar Posts: 1
    edited August 2019
    Changing to a different charger worked for me. Thanks. [SOLVED]
  • bucheckerrbucheckerr Posts: 1
    This didnt help me idk whats wrong
  • swagmaster120swagmaster120 Posts: 1
    im playing roblox on my oculus go when its done
