Power bank for oculus quest
24_7gaminghub24_7gaminghub Posts: 544
Its well and good to pre-order a case with your quest, but isnt it necessay to get power bank to support your oculus quest.
I, myself have a 3200mh power bank to pump more juice into the go, and even though I havent pre-ordered a quest,  I am preparing. I even have a belt pouch to support it.
What do you think? Is it worth puchasing?
  • 24_7gaminghub24_7gaminghub Posts: 544
    Admin delete thread. Didnt realise there was another thread  regarding portable power fot quest.
  • inovatorinovator Posts: 2,227 Valuable Player
    I have one for the go also but it gets very hot and have been afraid to use it to long. How long have u used it in one sitting?
  • TomCgcmfcTomCgcmfc Posts: 1,746 Valuable Player
    I found that the secret in using a powerbank with my Go is to have a fully charged Go to begin with.  Then it will just draw enough off it to continue to power the Go.  I watched a 2 hour movie and the Go did not overheat.
    I found that if you start with a partially discharged Go (esp. anything less than ~80%) is that it will draw power plus charge the Go battery and this seems to be when a lot of heat can get generated.
    Custom built gaming desktop; i9 9900k (water cooled) oc to 5ghz, gtx 1080 ti (from my old AGA), 32 gb 3000hz ram, 1 tb ssd, 4 tb hdd.  Asus  ROG Maximus xi hero wifi mb, StarTech 4 port/4 controller sata powered usb3.0 pcie card, Asus VG248QE 1080p 144hz gaming monitor, Oculus Rift cv1 w/2x sensors, Vive Pro, Vive Cosmos, Vive Wireless.
  • AfflosparkAfflospark Posts: 5
    Hey
    As I read you want some suggestion on a power bank. So I can recommend the Anker Powercore series. I have the Powercore 20000mah that should give me round about 24h of VR.
     If you want to try a beast so you can also try USB C Power Bank RAVPower 26800 PD Portable Charger 26800mAh (Fast Recharged in 4.5 Hours &USB-C Input, 30W Type-C Output) which is pretty awesome for gamers who play games whole day
    Hope this will help you.
    Thanks
