Oculus Go does not charging with a charger less than 2 Ampere?
HeigeHeige Posts: 2
Hello,
I try to charge with an old Chrager from Iphone, means less than 2 Ampere. I assume that this takes longer than an 2 Ampere Charger, but it doesn' charge my Oculus go and I charged the whole night. Just 3%???
Anyway I will buy the right charger, but I'd like to know if anybody had the same behavior.
Thanks for your answers
Heige
  • NeokinNeokin Posts: 94
    You need a charger with these specifications: https://support.oculus.com/536364990076727/
  • OmegaM4NOmegaM4N Posts: 653
    I am just using a standard USB adapter that came with a old tablet, works a treat.
  • nalex66nalex66 Posts: 5,203 Volunteer Moderator
    Yeah, if you have an iPad charger lying around, that’s what I use and it works perfectly.
  • TomCgcmfcTomCgcmfc Posts: 1,739 Valuable Player
    I don't have any problems charging with either my iPhone or Kindle usb chargers.  Both are 5v1a rated.  Both seem to charge up pretty quickly (1-2 hours depending on how discharged it was).  I try not to let it get below 30-35% before recharging.
    Custom built gaming desktop; i9 9900k (water cooled) oc to 5ghz, gtx 1080 ti (from my old AGA), 32 gb 3000hz ram, 1 tb ssd, 4 tb hdd.  Asus  ROG Maximus xi hero wifi mb, StarTech 4 port/4 controller sata powered usb3.0 pcie card, Asus VG248QE 1080p 144hz gaming monitor, Oculus Rift cv1 w/2x sensors, Vive Pro, Vive Cosmos, Vive Wireless.
