Best way for meetings in Unreal Engine with VR
zeve3dzeve3d Posts: 4
Hello all,
We are an architectural lighting design company in Turkey. We want to present our designs in a VR meeting.
Which way and Oculus model is the best for us?
I understand that every headset needs a computer. Is there any way to do this with one computer and multiple headsets? (online or at the same room.)
  • zeve3dzeve3d Posts: 4
    And in case if it doesn't work, can I have a master headset (connected to the PC via USB and HDMI) and viewer headsets (connected to an HDMI multiplier connected to PC, but not connected via USB) ?
  • snowdogsnowdog Posts: 7,637 Valuable Player
    It would help to know what you're going to be using the headsets for so that we can advise you I think. A HDMI multiplier won't work. Your best bet would be to use standalone headsets I think like the Oculus Go or Oculus Quest because that way you don't need to use a PC.
  • Swifty0neSwifty0ne Posts: 39
    Buy like 50 Oculus Quests and set up a private room in AltSpace VR. :)  Put up a Basketball Hoop in the corner or something.
  • Hiro_Protag0nistHiro_Protag0nist Posts: 4,980 Valuable Player
    zeve3d said:
    Hello all,
    You want to present your designs in what way?  On a 2d screen or will you be importing 3d models/CAD?  You could use Bigscreen to present the designs on a large screen.
    How many people would you want at these meetings?
  • w_benjaminw_benjamin Posts: 190
    The 50 Quests sounds good.
    That way they could join the meeting almost anywhere (They'd need a WI-Fi network to log onto)
    They also wouldn't need a PC to go with it.
    And the basketball hoop is a nice touch to build some camaraderie.
    zeve3d said:
    Hello all,
    Hello,
    I want to present the designs in Unreal Engine with VR. We are already using Oculus Rift for that, but we can only use one headset. We want to put 4+ people inside our project in VR at the same time. The real problem / question is, do we need a PC for every headset? Or is there a way to use 4+ headsets in only one PC?
    zeve3d said:
    zeve3d said:
    Hello all,
    Hello,
    We import 3D models into Unreal Engine with lighting etc. and then look at it in VR. (Sorry for poor English :)
