Quest guardian system sensitivity
ClavusClavus Posts: 19
Is there a way to change the sensitivity of the guardian boundaries on Quest like you can with the Rift on PC? I find that the guardian boundaries pop up waaaay more often, from longer distances, than they do for me on the Rift. Pretty much every fast motion while standing in the middle of my 2x2m tracking space also triggers it briefly, I can't play Beat Saber without the boundaries constantly popping up.
I know they're there for safety but this is kind of ridiculous.
  • ReBornTheFirstReBornTheFirst Posts: 15
    edited May 2019
    Yep, same here. BoxVR and Beatsaber are triggering the Guardian with every fast movement. It's annoying.
  • DreaglegDreagleg Posts: 43
    There was another post about this which included a link to a tweet from the developers which said they were working on this.
