My roblox audio goes through rift headphones.
G4M3R_55G4M3R_55 Posts: 1
I'm trying to play roblox. 1. It took me 20 minutes to turn vr mode off. 2. after i did all that. audio played through the headphones. i try setting my headphones to default audio device,Nope. I try closing Oculus home. nope. i try everything. doesn't work. I've read another post with this problem. i tried everything there. doesn't work as well.
  • sraurasraura Posts: 589
    If you go to oculus software devices tab, you can find additional audio related settings by clicking the picture of your HMD.
    Also check that when you left click the speaker icon on your taskbar, it shows the device you're trying to play the audio from.
  • jayhawkjayhawk Posts: 812
    install this
    solved all my audio problems. If audio doesn't switch over the way it should, this just makes it super easy to manually change it.
  • MrKrabszMrKrabsz Posts: 6
    edited June 24
    Which version of the game and VR are you using, OP? I was testing mine Oculus with this one and the sound was okay, though I had different issues with graphics and input lag.
