No display port connection, but connected and active???
soyeahstuff
Honored Guest
I'm using a 15 foot extension cable for both the displayport and USB.
The USB has the checkmark in app, however the displayport does not. I've
tried all 3 displayport holes on my GPU (MSI Gaming X
Trio 2080). It now
says Connected and Active but also no displayport connection??
portuose
Honored Guest
SAME...
Anonymous
Not applicable
portuose said:
SAME...
Exact same to this poster from May?
Same extension cable?
If you want help it would help if you would post your own details including system specs, etc.
Otherwise - well ok then.
