Oculus Rift S not connecting / not detected
reivaxrmreivaxrm Posts: 2
I've received my new Oculus Rift S two days ago and the only thing that I've got is disappointment.
The setup program does not detect the headset. I plug the USB 3.0 connection and nothing happens. No error or message appears in the Windows device manager. Obviously, the same result if I connect the displayport some seconds later.
Windows updated, USB, graphics card, motherboard drivers updated. Oculus drivers uptaded using oculus-driver app. All to the last version and absolutely no activity when the setup softare is waiting for the headset.
I've reinstalled Windows and the Oculus setup software many times. I've even tried it only connecting the headsed alone and all the other USB 3.0 ports with nothing connected.
All my USB 3.0 ports work perfectly with any other device. I'm afraid that the headset that I've received is dead.
Please, can someone help me? Thank you very much.
  • lensmandavelensmandave Posts: 438
    What Don says...or..try unplugging the display port from the PC, wait a few secs then plug back in. This woke the Rift up for me.
    Intel Core i7 6700K @ 4.5GHz. Asus-Z170-PRO MB
    CORSAIR H105 HYDRO CPU COOLER.
    NVIDIA GeForce GTX1080ti. 16GB DDR4 2666MHZ HYPERX SAVAGE.
    SAMSUNG M.2 SSD 128GB SM951 Boot Drive. SAMSUNG SSD 500GB EVO Working Drive.
    Windows 10  64bit Professional
  • shepherd23shepherd23 Posts: 2
    dburne said:
    Try unplugging the Rift cable from the headset. You have to take the front cover off to do so.
    Then plug it firmly in, it will push in most way then a little resistance, but push a little more and it will fully seat.
    How do you take the front cover off on the rift s?  I can only find how to do it on the rift which appears to be a bit different.
  • MaritalArtsMaritalArts Posts: 1
    It's pretty simple. The rubber nose piece easily pops out of the little holes in the bridge, then you can pull the tabs on the side out without too much trouble. After that take either corner of the rubber eyepiece (NOT the foam) and pull it straight off, there's six spots it will pop off of all the way around. This exposes the plug which will take a good but of wiggle and tug to get loose and as dburne said will slide back in easily and then resist before fully seating. If the USB is plugged in while you do this you should hear the windows tone of a USB device being plugged in once it's seated.
  • reivaxrmreivaxrm Posts: 2
    You were right. The cable was not well connected in the headset side. As simple as that. Thanks a lot for your help.
  • dburnedburne Posts: 4,055 Valuable Player
    Good deal!
    Don
    Thank you, that was easier than i expected.  It did fix my problem, but only for about 5 minutes then it lost tracking again.
  • ChinwiskersChinwiskers Posts: 1
    return this bad product,  i tired with it , i pack and return
    oculus for me is a dumb company
    their software cant keep in memory what we have set and each tme i need to repear and update firmware for my headset is recognised
    tired, tired, tired to do that, that broke the vr experience
    piece of garbage
    i hope oculus read that !
    is a big FAIL
    many people return to take the INDEX or REVERB, is the best way to do !
    I own the Oculus Rift S .. had none of your problems, so you were just unlucky? Don't come here and spread disinformation thats the very worst thing you can do.. share your experience sure but don't assert it like thats the experience every single person will have with this product..
    piece of garbage
    is a big FAIL
    Working beautifully here...
    Take care,
    Don
  • MorgrumMorgrum Posts: 1,799 Valuable Player
    Good luck with the next headset I guess.
    They all have similar faults or issues I.E. none of them are plug n play though the S was close to that for me.
  • ajayent48ajayent48 Posts: 4
    Type your comment
    I use the Oculus rift s and have the appropriate drivers installed on my PC. However, following the initial boot up of my PC the device is not recognised. I then run a package called Reimage and can see it has reset in device manager. Downside: Oculus then requires me to go through the setup procedures each time. I have to follow these procedures every time I boot up my PC. But it works.
    I have spoken to Reimage who have stated that the matter will not be attributed to their software which only repairs Windows. Also, the problem started before I installed Reimage. Luckily it is this software that is allowing me to use the Oculus following the procedures previously mentioned.
    I initially had the Rift CV1 which gave me no problems. When I got the Rift S, I installed it accordingly with up to date drivers etc using their install software method. It worked OK until I restarted my PC. Then I noticed that the Rift was not shown as installed in the device manager. Instead there was the yellow flag showing uninstalled. I checked for viruses on my PC, updated windows and even went as far as to reinstall windows 10; yet the same issue remained. When it does work, the Oculus runs well on my very up to date i5 machine with a very high spec Video card. I am not sure what it can be and think perhaps it is a Window compatibility issue. Possible one of their latest updates causing the problem.
    Oculus are looking at my logs which hopefully will lead to a solution for me and others suffering this problem.
    Update:-
    Thanks Oculus for all your swift help. A good product well supported and on occasion misunderstood by some out there.
    Oculus Response:-
    So I have reviewed both files you have provided and thank you as this shows me what is changing before and after the program runs.
    This is what I found from your Log files:
    From the log files "Not working state"
    1WMGH520B29285 is connected to: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller
     From the log files "Working state"
    1WMGH520B29285 is connected to: Intel(R) USB 3.0 eXtensible Host Controller
    When I checked the USB under the component tab on system information I see your have Intel(R) USB 3.0 eXtensible Host Controllers and the Intel(R) 7 Series USB host controller.
     I would like you to try the following since the ReImage program is doing this upon booting up:
    Uninstall the Intel(R) 7 Series drivers and install Microsoft drivers:
     Open Device Manager
     Right-click on the Intel(R) 7 Series card
     Select Uninstall Driver.
     Restart computer
     Allow Windows to install USB drivers automatically or select the Microsoft driver through the device manager under the USB controller
    Bingo!! It works.
    I hope that this helps others out there who may be having the same problem.
  • giuseppe.gerardigiuseppe.gerardi Posts: 1
    Tutto bene con oculus cv1, arrivato oculus rift s, collegato al PC ma non rilevato dalla applicazione
  • barongergvbarongergv Posts: 6
    piece of garbage
    is a big FAIL
    right there with you, no matter what I do it's just getting worse.
    There are some serious issues with this and Oculus doesn't seem to give a shit.
  • MudonisMudonis Posts: 5
    can somebody tell me how to find these log files?
  • ManydoorsManydoors Posts: 21
    Bought mine last week and it has lost connection twice already and it took me a lot of messing about to get it working again.  It has me worried that I made the wrong choice when buying.
  • HumanHyperboleHumanHyperbole Posts: 1
    I'm having a similar problem. It worked for a few minutes, then after trying to launch a steam game it crashed and never recognized my USB 3.0 again. I tried the suggestion for unplugging then replugging the cable on the headset itself several times, checked my usb 3.0 drivers, all fails.
    I've looked around and it seems to be a common issue and it seems there's never a one size fits all fix for these usb 3.0 issues.
  • ttsceattscea Posts: 1
    After having this same problem for some weeks I bought an external "powered" USB3.0 hub. Plugged this hub into a USB3.0 port of my PC and plugged my Rift S headset into the powered hub. Since then I have never had a problem.
    It would seem this issue is due to the headset trying to draw too much power from the motherboard USB ports.
    Using an external powered hub takes away the low power problem.
    Good Luck and hope this helps all others suffering this problem.
  • BuzzaragBuzzarag Posts: 1
    So is there any real fix for the Display Port in infinite search circle problem? Everything works except that my PC can't seem to find the Display Plug like it is for many more. I tried pretty much everything now and it still doesn't work. For that much money quite the disappointment.
  • richyjay420richyjay420 Posts: 1
    YOU SAVED MY VR! was about to freak tf out thanks
    Good deal, you are most welcome!
    Don
  • camowrathcamowrath Posts: 2
    I have scoured the internet for any solutions, i bought this thing yesterday, installed the oculus app overnight and now the lights on the headset wont turn on and the oculus app doesnt recognize its plugged in. last night when i plugged it in initially it had orange lights turn on and now theres nothing. i tried unplugging both cords in the computer, plugging in the usb, waiting 5 seconds and plugging in the display plug and nothing. i checked the display cord on my headset and i got nothing, i tried different usb slots and nothing. im at my wits end here and ready to just give up.
  • ilolasilolas Posts: 1
    Unfortunately, nothing here helped me. I am scared that my Rift S is dead.
    I had it for like a week, yesterday it completly stopped working.
    USB  eXtensible Host Controller - 1.0 (Microsoft) Gives me error 43.
    Its also worth noting that I had problems with my rift s since I bough it.
    It lost tracking, Reconized my USB 3.0 port as incompatibile, but it worked. So far I am highly dissapointed with the product.
  • Umpa_PCUmpa_PC Posts: 835
    @ ilolas
    Open a support ticket.  You have not provided any information that anyone on here could use to try and help you.
    Windows 10 Home Edition Version 10.0.18363 Build 18363, Oculus version 17, Quest Version 17
  • ReeferF80ReeferF80 Posts: 1
    edited February 1
    dude.... thank you. Was driving me nuts. Always something simple and I overthink it. You spent 20 seconds typing a response that helped a bunch of people enjoy their toy again. Good on you bro - you should feel good about yourself.
    Thanks! Always glad to help where I can.
    Don
  • VR2018FRVR2018FR Posts: 51
    edited February 2
    just try to unplug your  headset (usb and display port) turn off your PC then restart  your computer and when windows is loaded, plug your usb port 10 seconds  after your display port and it might work. I have to do this every day for the headset being recognized.
  • jonglinesjonglines Posts: 1
    I spent a ton of time trying to get my Oculus Rift S to get a green-light on my USB 3.0 connection.  I tried every port and that didn't work.  I then bought a powered USB 3.0 hub but that didn't work.
    I finally bought this PCI Express expansion card  from Amazon and finally got the Green light on the USB 3!
    Make sure you have an empty PCI Express slot before you try this!  https:// amzn.to/2GS24Gd
  • BasementDocBasementDoc Posts: 4
    Purchased two new Aurora R9 and two new Rift S. Processing power wasn’t an issue – compatibility is a major issue. The Rift-S has buggy hardware and software, making installation and use extremely difficult (see reddit and other oculus threads on all the freezes/stalls/failed install/startup, etc.) with a main culprit being the USB ports. Apparently, the Alienware Aurora USB 3 ports don’t work well and the findings were replicated on two new independent systems, confirming a design flaw. Only one USB port (front middle port) worked OK with Rift S. Like others here, invested more than a dozen hours of reading forums, reinstalls/downloads (we clocked >80GB of repeat downloads of oculus install software), turning off power saving features, virus protection, switching USB drivers, testing different ports, re-installing half-dozen times.  It's working for the moment, but Rift S is not the solution for widespread VR, so it's not surprising to see Facebook giving attention to Quest (we have two of those, which work fine).  Concerned they will ignore the higher end Rift S as may be minor software income relative to Quest due to sheer numbers.
