Last Doom post: RiftS with DoomVFR problem
C-R-O-N-O-SC-R-O-N-O-S Posts: 4
I have problems with DoomVFR.
No posts are helpful or stuck at the same place.
The performance is good and always at 90 fps.
Only with head movements it jerks extremely.
If DoomVFR should run on you RiftS please give your specifications.
Driver version, Oculus Vers., nvidia settings, Windows Updates?!
Thank you!
  • RattyUKRattyUK Posts: 1,174
    I have just downloaded and played a little, all appears to be good so far :)
    Specs in sig...
    PC info: AMD Ryzen 7 2700X, MSI MPG X570 Edge, 16GB Tforce Pro Dark DDR4 3200, KFA2 RTX 2080 Super, Samsung 870 Pro M.2, 2x 240GB SSD, 3TB WD Green HDD & 4 TB Seagate Barracuda HDD, Antec Modular 750w PSU, custom watercooling loop. (Win 10 Pro & Opensuse Leap 15.1 Linux) 32" AOC 4K Monitor.
    Rift S
    Laptop: Aorus X5 V6-CF1 (I7-6820HK, GTX 1070, 2* 256GB M.2 NVME, 1TB 7200 HDD)
  • C-R-O-N-O-SC-R-O-N-O-S Posts: 4
    edited June 2019
    Very interesting!
    I also have a 1080 and Win10.
    Which graphics driver do you have and which Windows10 build?
  • MowTinMowTin Posts: 1,916 Valuable Player
    edited June 2019
    Thank you!
    I'm running a 2080 ti. Settings maxed. Sharpen 2.0. I have 100% supersampling in Steam VR (no supersampling).
    I leave it at no supersampling because I assume Sharpen is a form of supersampling. Am I wrong about that?
    Also, I use the hack that allows you to have smooth turning since Bethesda is too lazy to add smooth turning.
    i7 9700k 2080ti   CV1, Rift-S, Index
    edited June 2019
    It runs ok but not dead smooth for me. You can add turning/jumping via the AutoHotkey Script and edit it as in threads here.
  • RuneSR2RuneSR2 Posts: 5,307 Valuable Player
    I'm wondering if the game still uses 60 Hz tick rate. Doom 3 did meaning that the only way to get perfect smoothness was to get 60 fps in 60 Hz. Because no matter what I do Doom VFR isn't perfectly smooth, even if I get solid 90 fps. But the game plays fine still, and most will probably never notice this potential issue - if it's still hidden in the engine.
    Very interesting!
    Windows build is 1709 and the very latest Nvidia driver - I also use an Xbox for Windows controller as I CBA to install AutoHotkey to allow me to turn...
    Rift S
    With Steam VR you have to always check the Steam VR supersampling settings.
    In steam the ss settings are set to 100%.
    But as I said, the performance is GOOD.  I have Win10 1809 and also the latest Nvidia drivers.  Either it is a setting in the driver or Windows.  Does it go with someone who has Win1809?
    edited June 2019
    It goes but isn't brilliantly smooth. By that I mean each 5secs it glitches slightly and that isn't the whlte flashes either and CV1 did the same too (without white flashes obviously).
  • SLM101SLM101 Posts: 13
    I'm also getting strange jerky movements using Rift S on Win10/i7 4770k @4.4GHz/GTX1070/16GB RAM. The whole game seems to run perfectly but in some rooms the movement is kinda jerky/shakey despite running at a high framerate. The room with the smaller 3D models on the benches at the begining is a perfect example.
  • snowdogsnowdog Posts: 7,486 Valuable Player
    Have you tried running the game with OpenComposite? Should get better performance if you take SteamVR out of the equation.
    OpenComposite does not work with this VULKAN version. >:)
