No sound on Oculus Headphones
EthanWarren18EthanWarren18 Posts: 2
Hello. I have an Oculus Rift and recently my Right Headphone has stopped working. I decided to keep playing with just my left ear and today my left earphone has stopped working. The issue is that it only works when the headset is fully loose on both sides and I can't play like that. My Rift is also out of warranty so if there's nothing you can do that's fine. Thank you.
  • EthanWarren18EthanWarren18 Posts: 2
    Just realised I'm on FOrums. Damn it
  • sraurasraura Posts: 590
    Well the screws which hold the headphones at their place have probably loosened and that effectively causes the issues you're describing. With your rift you got a plastic "screwdriver", which can be used to tighten them back up.
