Blue Led lights blinking in Standby
blindxxblindxx Posts: 3
Does anyone know what the color LED lights in standby mean? My headset while charging the led light blinks blue. I looked at what the support site says the color led mean and I do not see what this means. Also at one point the other day it started blinking green. I dont think there is any issues, just curious if anyone knows what they mean.
  • nalex66nalex66 Posts: 5,421 Volunteer Moderator
    I think it blinks blue when it's communicating with the phone app via Bluetooth.
  • blindxxblindxx Posts: 3
    That makes sense.  To confirm later I will turn my phone on airplane mode and see.  What would you guess then blinking green is?  Only once have I seen it blinking green.
    Not sure, I've never seen it blink green.
    I figured it out.  I had contacted support but they did not really help.  I was using it tonight when I got a Facebook notification popped up in the headset, I had the same notification on my phone. After opening the notification on the phone in the Facebook app the headrest light stopped blinking and switched orange as it was plugged into the charger and charging.
