Need help with integrating Lip-Sync in Unity
Yurnero99884Yurnero99884 Posts: 3
I tried integrating lip-sync using Oculus integration from the Unity Asset Store, following instructions from the lip-sync guide but it doesn't work on my instantiated character until my app loses focus. It starts working after my app loses focus (if i alt-tab back into the app) but then it's messing up with my microphone and Photon Voice stops working. Any help would be appreciated, thanks.
  • nalex66nalex66 Posts: 5,619 Volunteer Moderator
    Try asking in the Developers forum, there are some knowledgeable people there who can probably help.
