Lone Echo constantly crashing please help
[6-15-2019] [21:14:56]: === System Info ===
[6-15-2019] [21:14:56]: CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
[6-15-2019] [21:14:56]: Num Physical Cores: 8
[6-15-2019] [21:14:56]: Num Logical Cores: 8
[6-15-2019] [21:14:56]: Memory: 32 GB
[6-15-2019] [21:14:56]: Process Committed Memory: 6137 MB
[6-15-2019] [21:14:56]: Process Peak Committed Memory: 6588 MB
[6-15-2019] [21:14:56]: Process Working Set: 2512 MB
[6-15-2019] [21:14:56]: Process Peak Working Set: 2512 MB
[6-15-2019] [21:14:56]: System Committed Memory: 15189 MB
[6-15-2019] [21:14:56]: System Max Committed Memory: 37804 MB
[6-15-2019] [21:14:56]: System Physical Memory Used: 7190 MB
[6-15-2019] [21:14:56]: Video Card: NVIDIA GeForce RTX 2080
[6-15-2019] [21:14:56]: Driver Version: r430_00 (43086)
[6-15-2019] [21:14:56]: Dedicated GPU Memory: 8010 MB
[6-15-2019] [21:14:56]: A crash was detected while running thread: Task Kernel
[6-15-2019] [21:14:56]: [Aggregated 1 times] Unblocking monitored fence
[6-15-2019] [21:14:56]: [Aggregated 1 times] CliD3D11CompositorClient::release 1
  • SaufySaufy Posts: 4
    same happend to me :( It's crashs after 20 minutes
  • dburnedburne Posts: 2,981 Valuable Player
    Same here - have not been able to run Lone Echo since getting my Rift S. Tried it with CV1 and same result also.
    Mine crashes to desktop after about 5-10 minutes.
    Don
    i have crash with revive / Vive Pro and with Oculus Rift
  • RuneSR2RuneSR2 Posts: 4,246 Valuable Player
    My son played it for about an hour two days ago - no problems, all settings maxed apart from MSAA. CV1 1.37 - Forceware 4.17.
  • bportjoeybportjoey Posts: 4
    Perhaps the game isnt optimized for rtx cards?
    I solved it!
    I put down the Graphic.... Temporary AA off, and all on medium. Now it works!
    I figured out my issue, I had a bad over clock on my CPU. The game runs flawless with Max settings even with SLI enabled
    Are you overclocking your CPU? If so try adjusting that, that was my issue game runs like a dream now for me
    I had overclocked my cpu too but tried default setting... same issue, only lower settings soved it. And i had 90FPS with highest settings. 8700k and RTX 2080 TI
    I will re-install and try lowering my settings some, I have a beefy system and had the graphics maxed out.
    Would be a shame if that is what it requires to get it working, but will give a shot here in next day or two and advise.
    Don
    Try the game with no overclocking at all - if it doesn't work, then it may be some software incompatibility - or else ;) Lone Echo may be the one game to really push your hardware. SLI isn't supported in VR, and maxing out all settings probably will force your fps below 90 in some places. Otherwise try to lower MSAA slightly - using resolution 2.0 it's not big deal with MSAA - but you do need to activate the temporal antialiasing even when using resolution 2.0.
    Nope no difference.
    Set all graphics to Medium rather than High, same exact issue.
    I have played Lone Echo many hours previously with no problem at all.
    I may try setting some GFX individually as a last shot, but if still no go I will uninstall this thing for the last time.
    I play some way more intensive games - namely combat flight sims like DCS and IL-2, without any hiccup. Also my other Oculus games. The problem is isolated to Lone Echo for me, and obviously I am not the only one.
    Don
  • KeksmaniaKeksmania Posts: 4
    My game crashes right after starting. It ran a bit laggy in the first 2 hours of the game and now it instantly crashes when I load the game.  ( i7-4970k, gtx 1080, 16GB ram)
    Even when I play on low ._.
    I gave up and uninstalled it for the final time. Sent a ton of feedback to the devs after each game crash, has my contact info but no word from them at all. Not sure why they even included a feedback option along with contact info after a game crash.
    Darn sure won't be purchasing Lone Echo II when it comes out.
    I have several VR games and all the rest run just great.
    The problem is with Lone Echo.
    Don
    edited October 2019
    Hey gang,
    Thought I would re-visit this after a few months and see if anything changed.
    Nope, still getting crash to desktop every time at a certain point, usually just after the calibration program crashes and I am back stuck in Pod with Liv talking to her superior about the transfer without Jack,
    Right when she realizes Jack is there and comes over to see what happened.
    I completely uninstalled Malwarebytes ( Free Edition) to rule that out.
    I have several Oculus games that all run great, and a few non Oculus VR games that run great as well.
    And of course I have submitted the feedback after each crash multiple times to devs, and never get any feedback on it, so apparently no support for this game whatsoever.
    I am attaching the r14 Log file, maybe someone smarter than me might can tell if there is a hint in there of the cause?
    I don't know why I keep coming back to try this game, guess mainly the curiosity in me why I have one game that absolutely will not run. Other than that I would just consider it a waste of money and move on.
    Thanks for any help,
    Don
  • sford52sford52 Posts: 175
    The last line of your log file says: "[10-7-2019] [9:37:31]: A crash was detected while running thread: Task Kernel "
    Can you go into your EventViewer and locate the event and post it?  The event may be in "WindowsLogs->System event" (Assuming Win 10)
    ASUS ROG Strix GL702VS-AH73 17.3" Laptop.  I7-7700HQ, GTX1070, 12 GB DDR4 RAM, 500 EVO 970 GB SSD, VS 2017, Oculus rift, Windows 10 home
    From the Windows Event Viewer:
    The description for Event ID 1 from source BugSplat cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
    If the event originated on another computer, the display information had to be saved with the event.
    The following information was included with the event:
    rad
    loneecho.exe
    33433
    Don
    edited October 2019
    Don, my guess is that the game needs at least a repair, and I would just go whole hog and do a full uninstall, reboot, reinstall. Before going to that extreme you may want to try submitting a ticket to Ready At Dawn.  If you decide to go the uninstall route, I dont know know if Oculus has a formal process to remove a game, at the least I would use the uninstall from your Oculus library. However, if you decide to that, I would first figure out the physical directory location for the game, it will be something like C:\Oculus Apps\Software\ready-at-dawn-lone-echo. Then after you uninstall the game using your Oculus Library, check and confirm the directory is in fact removed from you disk. This step may not be needed, it may be removed by Oculus, or it may be that it doesn't need to be removed I dont know. But, If I were to want to remove it, I would make sure it wasn't on my disk. Also, delete the ready-at-dawn-lone-echo files in the manifests directory C:\Oculus Apps\Manifests\ready-at-dawn-lone-echo.*
    At this point the game is gone, uninstalled, removed.
    Now, reboot and install it again. Make sure all your anti-virus is off during this install. When you play it again, use a clean system no cpu/gpu overclocking and just one monitor. This may be overkill but it helps the debugging process to start from a known state.
    You may want to wait for a more knowledgeable Oculan to chime in, or a response from Ready At Dawn.
    Anyway, good luck
    Many thanks sford52 for the feedback.
    I have done the complete uninstall a few times in last few days, only thing perhaps I did not do was check for and delete any manifests in the Oculus installation directory, guess I could give it all a try again.
    I know I deleted everything out of the other directories.
    Don
    Uninstalled again and made sure everything was cleaned out.
    Now it crashed to desktop right after loading whilst Liv was first talking . Again it asked me to submit the report including my name and email address - not sure why they offer that option as this is obviously a one way communication street.
    I tell ya I think I need a throwing in the towel emoji, just tired of messing with this for so long.
    All my other VR games run perfectly, some way more demanding than this one. I know my case is unusual, but I am convinced there is nothing on my end that can solve it. I am normally very good at trouble shooting having built PC's for well over 20+ years, this one is nuts.
    I have attached copy of r14 Log File from this attempt. It is all Greek to me but maybe someone might see something that gives a clue.
    Don
    edited October 2019
    I understand your frustration, its good that you have systems/computer experience and know terms,procedures and debugging. The problem could be any number of things, a problematic graphics driver, VS C libs out of date, directory permissions, disk space, ... or any of a number of other things. I see four things but I don't know what they mean. Since you've done a few reinstalls it doesn't feel like that is the problem
    1) Failure of C:\Users\Don\AppData\Local\Oculus/*.json.   Not sure why  this is happening, but at least it does fail to a default.
    [10-8-2019] [9:33:8]: Failed to open file: C:\Users\Don\AppData\Local\Oculus/ProfileDB.json
    [10-8-2019] [9:33:8]: Failed to open file: C:\Users\Don\AppData\Local\Oculus/Profiles.json
    [10-8-2019] [9:33:8]: [HMDState] Using default profile default
    2) No r14 size specified for gamespace. I dont think this is serious, I have them in my log files.
    [10-8-2019] [9:33:9]: [LEVELLOAD] Enabling level '0xAC360E41E4EDE056'
    [10-8-2019] [9:33:30]: No r14 size specified for gamespace: 0x3E94878179EEB87C
    [10-8-2019] [9:33:30]: No r14 size specified for gamespace: 0x11A9679DDD15B318
    [10-8-2019] [9:33:30]: No r14 size specified for gamespace: 0xEA49EB391EDD4030
    3) Failure to find script binding. This feels like it would be serious.
    [10-8-2019] [9:33:32]: Failed to find script binding for 0x079EC86F745E724B
    [10-8-2019] [9:33:32]: WARNING: Failed to find script setdata binding for 0x079EC86F745E724B
    4) There are six sets of these errors, each set having 2 occurrences of "invalid channel ID"
    [10-8-2019] [9:34:20]: ~ CSetAnimationRealChannelNode has invalid channel ID ~
        Script:           0x3E94878179EEB87C
        Node UUID:        50c108d6
        Target Actor:     0x41D2D7311B3A020C
        Channel:          0xDE7A93EF2E46CBA7
    Encountered an error:
    [10-8-2019] [9:34:20]:  - 0x2FD48A8D4C79448D
      - 0x2FDA8A8C4D75508F: Invalid channel ID or channel alias ID '0xDE7A93EF2E46CBA7' specified while animating rig '0xC05A38189F7EDD79'
      - 0xB4130B7A4AC7E049:
      - 0xC8C33E483C7A12B5: d:/projects5/rad14/dev/src/engine/libs/animation/canimcontroller.cpp
      - 0xC8C33E48367A10B5: 844
      - 0x5CDBDD908EB88C3B: 1832073928955681522
    I'll continue googling errors and comparing with my logs. I hope that the RAD folks give you a pingback.
    Thanks much for the feedback @sford52 .
    All my drivers - motherboard, usb, gfx, audio are up to date and as I mentioned I have several other Oculus and other VR games that run quite well without a glitch. Also my Windows 10 version 1903 is up to date.
    I have tried running Lone Echo with just about every combination of graphics settings that I can think of.
    A real head scratcher.
    Don
  • JcTrickYJcTrickY Posts: 2
    Hello i have the same crash with a 2080ti and a 9900k perhaps it's related to rtx model of graphic card... Like you all my vr game works perfect... And like you said there is NO SUPPORT from the developper at all... It's a shame, the game is great but crashing all the times finish to kill me... Also another bug to notice if you move lone echo directory via oculus you will loose all your saves....
    edited January 14
    I gave up and uninstalled for the final time.
    Lone Echo was a complete waste to me.
    Developers apparently do not give a rats ass either.
    I certainly will not be purchasing any more from them.
    I have many other games, and they all work fantastic.
    Don
