Fan noise
denodandenodan Posts: 40
How many can hear the fan in their quest? Have read some can and some cannot.
I noticed last night if I hold mine up to my ear can hear the fan. If I put my quest on eith no sound can just hear it. With sound cannot.
I know there will be some fan noise, so how noisy is yours? As I have read it does very.
  • MrCr0aMrCr0a Posts: 11
    I can hear it if I stick my head directly on the front's quest but it's very discreet. In game I just can't hear anything.
  • enigma01enigma01 Posts: 980
    Yeah it’s quite normal to hear it if you stick your ear up to it. I can too.
  • Cer3alCer3al Posts: 4
    I've been struggling to know if the noise I hear from the Quest is normal.
    In a quiet room(late night) I can hear the fan working, and I don't have to put it near my ear.
    If I have the headset on and almost no sound.. I notice the fan.
    It seems is more of a resonance issue. If i apply a bit of pressure with my finger on the front plastic.. it reduces the noise.
    Because of reading that there's some people that never hear it... I replaced the headset.
    The new one arrived, the sound is a bit lower but still.. I can hear it.
    Or I had bad luck and got 2 Quest in a row that have a problem... or my hearing levels are much higher than normal.. <_<
  • denodandenodan Posts: 40
    Think you will be fine. Playing a game with the sound on, even low and you dont hear the fan.
    I know I had only recently noticed it and think recently was playing with no tv or any other sounds around.
    You would know if your fan was no good. A good even sound is a good fan.
    There can be times that the game has like a silent part and i can notice the fan.(late night without ambient sound)
    I know it's fine and i can live with it.
    I just want to make sure what's suppose to be the normal behaviour, and i want to have a Quest like it was meant to be.
  • SpuzzumSpuzzum Posts: 843
    I did the Deluxe Audio Strap mod...I don't hear any fans. :P
  • h.r.gargih.r.gargi Posts: 172
    In silent ambient I also can hear the fan when it lies on the table in front of me. I checked it on another device and it was the same. So I think it is normal. Some people say, they can hear nothing. So I also was a bit anxious fearing the fan is broken, but after hearing the other one everything was good for me :smile:
    German Oculus Quest / Go / Link Facebook Group ... join us
    https://www.facebook.com/groups/oculusquestgermany/
  • bigstatikbigstatik Posts: 19
    I didn’t even know it had a fan. I guess mine is quiet.
    There is a full internal tear down of the headset here:
    https://medium.com/badvr/oculus-quest-headset-disassembly-2f404b004a3c
    Quite interesting if you’re a geek like me! You can see the fan, and is quite large located very close to the front panel of the headset. Not surprising to be able to hear it in a quiet room really...
  • SirMarshallSirMarshall Posts: 13
    Never heard the fan in my quest.
    I found this video on Youtube..and it's something that i heard on my first quest and now on the second one. On the second one the "humm" sound is more light though.
    Can you guys also hear it on a quiet room?
    https://www.youtube.com/watch?v=dRDtxP3nOFY
  • useri7useri7 Posts: 18
    Yes, mine started getting loud after about 20 hours of use so I had to return it. I suppose the quality of the fan is not the best. I hope they will improve it in a later batch. Right now this keeps me from buying a new one.
  • berbekkberbekk Posts: 1
    I have same noise
  • StrongitStrongit Posts: 112
    That's a defective fan, heard that sound many times fixing PCs.  I'd get it replaced under warranty.
    I didn't even know mine had a fan until a week ago. I noticed some very minor background noise when headphones are plugged in and there's no sound playing.
    edited January 27
    On 4 different Quests I always notice a fan noise. Not very loud, but you can hear it clearly. But I have to say I have very good ears too and that's not always a gift  ;)
  • analogXanalogX Posts: 2
    i hear the fan on my new Quest 2.  I'm a pro IT tech and from my experience, not only do i hear the fan, it sounds like its failing or struggling to spin.    I can hear it in game while wearing headphones too.   Hmmm.....    There went the excitement of a new toy.   Now i envision, waiting, emails back and forth, slight headache.
