CV1 no sound rift plz help
my rift has some weird thing going on when I pull it out from my face I can hear but when I put it back on no sound please help
  • RedRizlaRedRizla Posts: 7,115 Valuable Player
    edited July 2019
    Try unplugging the the cables and plugging them back in. Failing that do a repair on Oculus Home.
    It's a very similar problem to this thread.
  • TF2vectorTF2vector Posts: 7
    sorry i clicked the button twice
    edited July 2019
    Yes it happens I was just joking. Try unplugging the the cables and plugging them back in again. Also the cable on the headset end.  Failing that do a repair on Oculus Home.
    i tried did not work
    You might have started to get the ribbon cable fault is the headset still under Warranty? Have you tried removing the headphones and reconnecting them? Sometime some dirt can get in there, but if that doesn't work you could be getting the ribbon cable fault. Does it work ok every time you put it on the first time and then lose audio the second time or is it intermittent?
    THANKS
