low volume / weak sound on oculus rift s
lordblack38
Honored Guest
Hello,
I have a sound issue on my Oculus rift S.
The sound is weak even i set the volume to 100% in most applications.
And there does not seem to be any problem when I plug in a headset.
Thank you for your help.
4 REPLIES 4
Fangzhou
Adventurer
According to my experience the volume 100% on Rift S is similar to the volume 10% on Rift CV1.
There was a software update to improved this (1.38). But the audio quality still bad and volume still very weak.
I bought a pair of on-ear clip earphones and mount them on headset to fix the audio.
lordblack38
Honored Guest
ok I will do that and wait an update
andrew1977au
Explorer
i bought a set of Sennheiser HD 4.30i headphones and they sound really good and fit over the rift s without issue.
Haswell 4790k@4.5 - MSI Z97 GAMING 5-  32GB GSKILL TRIDENT X 2933 - MSI VEGA 64 WATER 1700/1100 - SAMSUNG 950 PRO M.2 - ACER XR341CK - AX1500I - CUSTOM HARD TUBE WATERCOOLED GPU&CPU - 750D - K70 MK2 - M65PRO : Acer Predator G9-793 : OCULUS RIFT S
Anonymous
Not applicable
I purchased Klipsch R6 II earbuds and they sound fantastic with the Rift S.
I actually prefer earbuds myself anyway so that option worked out well for me.
