Better way to use for glasses users
Is there a way to make the Oculus rift better for a person who has to use glasses with it?
  • RichooalRichooal Posts: 1,336
    Rift or Rift S? They're very different.
    Most people recommend these aftermarket lenses.................
    https://widmovr.com/shop/
    i5 6600k - GTX1060 - 8GB RAM - Rift CV1 + 3 Senors - 0 PROBLEMS
    "If it ain't broke, don't fix it".
  • sraurasraura Posts: 589
    You could do this (not recommended) or something like this (which would be probably the safer option).
  • SpiceLife72SpiceLife72 Posts: 154
    I got widmovr inserts.  Much more easier than wearing glasses.
  • inovatorinovator Posts: 2,174 Valuable Player
    Yes heres how, buy the smallest glasses you can buy. Take off the glasses arms that fit over your ears. I then connected fishing line to make a head strap. It worked much better and far more comfortable. Even though the rift s fit glasses better now  my setup makes it even more comfortable.
  • john.zigmontjohn.zigmont Posts: 116
    I use to purchase WMR  lenses for all my headset when I received my Rift-S there wasn't need to purchase lenses I can wear the glasses when using the Rift-S.
  • laudbrianlaudbrian Posts: 13
    If you have a Rift S or Quest, I've been using these magnetic lens prescription adapters as they have totally changed my experience comfortwise, no more scratches or fog. Easy to remove if you're sharing with other users as the wife and kid have perfect eyesight. They are half the price of competitors WidomoVR, VR Optician and 3D printed just like the rest of them. All you need are these magnetic adapters https://www.etsy.com/listing/710848026/oculus-quest-rift-s-magnetic and $9.95 prescription lens from Zenni
