Rift Old Poor Tracking Quality Problem - After PC Sleep
SabrejetSabrejet Posts: 80
edited August 2019 in Support
Hey, it's been a huge while since I've been here.  I wanted to see if the users have found a fix for this problem.
At first, I was having the "Computer won't sleep due to OVRService running." So I would stop the service a few times, and now most of the time my computer will sleep without having to stop it anymore.
What happens now, and probably happened a lot in the past; When the computer wakes from sleep, my sensors report Bad Tracking Quality, and
USB Driver Update Recommended.  This seems to happen only after sleep.
Oculus Tray Tool earlier today reported: Fresco USB has entered power saving mode (right click to disable.)  I had done work on Device Manager and Power Settings to disable that earlier, but I right clicked and did it anyway.
Right now I'm looking at the same thing happening.  OTT is not reporting any errors this time however.  I don't really use OTT anymore, but thought it could give me some info.
I have the Inateck 7-Port USB 3.0 PCI-E Card KTU3FR-5O2U
850W PSU, X370 Killer SLI/ac Motherboard.
Hybrid Sleep Off.  (Now trying On)
Hibernate:  Never
All drivers are super up to date.  The original Inateck drivers seemed to be a problem if I remember.  At this moment, sleep seems to be the culprit.
One more thing to add:
Replugging usually fixes the Poor Tracking (but not always!) but it still says USB driver update recommended.
  • SabrejetSabrejet Posts: 80
    yep even hybrid sleep.
    Okay. Good news. This very old problem isn't solved, but it seems that after a while, Windows does get the drivers and sensors going and working normally after a while.  Right out of sleep it does the poor tracking quality thing, but after a while of not sleeping, it sorts itself out.
