Oculus quest three dots problem
futku1futku1 Posts: 3
hi,
I purchased Oculus quest. I made the full installation. There is a situation different from instrucrions it does not ask installation code and passes that section automatically. I match the device, connect wifi it recognize pads, installation ends and 3 points are appeared. The progress does not go on from that point. I cannot see the environment through the camera. There are always spinning loading 3 points screen and i cannot pass here. I restored factory settings several times from the goggle and smart phone both and reinstalled but it does not work. What should i do?
Thank you
  • JohanTEAJohanTEA Posts: 57
    edited August 2019
    First try and let it sit with the three dots spinning. The Quest usually try to make a firmware update after a factory reset. It might take a while, but not more than 30 minutes (the support recommend 4 hours though...).
    If that does not help, contact the Oculus support.
  • futku1futku1 Posts: 3
    support line will send mail.  but they don't.  problem not solved
    the problem is not solved. I don’t know what will I do. Support does not answer
