Oculus Rift S Display Port not connecting
imNyXimNyX Posts: 1
Hi, i seems to have this issue where, i'm unable to connect the Displayport Connection. And the GPU isnt Detecting it at all
>Tried plugging in the USB First and wait 5 seconds then put the Displayport in
>Tried Unplugging everything and leaving just the USB and Displayport
>Tried Turning off the settings for the USB Powersaving
>Tried Replugging even harder (didnt work any harder and i will plug the cable into my graphics card)
>Tried Redownloading all the drivers and it didnt work at all (Nvida and intel and motherboard)
Other then that, im also unable to update the firmware for it too for some reason it keep refuse to update
>Tried disable firewall/windows defender/antivirus Didnt work
>Tried unplugging everything and turning powersaving off    didnt improve
I asked Oculus Support but their reply is either repeating whatever im doing or just isn't helping. So i guess try my luck here and see whoever had the same issue and managed to resolve it can help? And issit possible to ship back to them and ask them to fix it?
Thanks
PC Specs
z170 pro gaming motherboard
i7 6700k
Zotac GTX 1070
Connecting Directly to DisplayPort to GPU
  • Nathanael_Nathanael_ Posts: 11
    I have the same problem, I tried everything (see my previous posts) oculus even sent out a new cable, still doesn’t work. I’m trying one last day then returning it and never buying oculus ever again
  • TheBruhTheBruh Posts: 1
    Im having the same problem I wanna die
  • raju.saini1732raju.saini1732 Posts: 4
    Same problem here! I bought mine this week and it worked well for a couple of hours. But after sometime the screen went black. Later when i tried to sort it out, i found that my display port is not being detected. I am using the mini display port adaptater on my laptop. I did everything that they have mentioned on their page from removing and reinserting the pins to reinstalling the software. I even once removed the app in safe mode and removed all traces of the app from App data. Even after that the display port is not working. I tried to contact support team and they helped me initially. Now i am no longer hearing back from them even after sending repeated requests on my ticket. I even once tried rolling back the rift s Firmware to previous version but no luck with that too. Has anyone here found any solution? Please help me with it.
  • VR2018FRVR2018FR Posts: 51
    you are not the only one ! I guess the problems comes with the latest  series (mine , it was an exchange)   and the thinner cable and the lastest software updates,   soon Ii will be  1 month for me and more  for others, I just  want to squash that piece of shit headset to the ground !  never  buy oculus  again ( anf if a miracle  happens  , I will buy my games only on steam)
