Controller tracking lag when using two-handed weapons
alrod360alrod360 Posts: 2
In just about every game that I play that uses two handed weapons (guns or bow & arrow) my arms begin to go crazy whenever I fire them. I was wondering if there was a fix to these bugs. Is it a problem with steamvr or a tracking issue?
  • parsecnparsecn Posts: 105
    Rift-S? What headset are you using?
  • alrod360alrod360 Posts: 2
    The Rift S
  • xx_FLoW_xx_FLoW_ Posts: 2
    Having the same issue with the Rift S. Every time i hold a gun in two hands and use the trigger to shoot.
    I've read that it can help turning off the passthrough mode or taking off the battery cover, but nothing helps for me.
    I have found the solution. I did two things:
    The USB cable of the headset was on a USB 3.2 port in my PC. I now have it in an USB 3.0 port.
    And the i had to go in the energy saving options on Windows and turned off the power saving option for USB Devices. Now everything works fine.
  • DSoltDSolt Posts: 4
    Is that happening to you?
  • sofiane.hocine1sofiane.hocine1 Posts: 1
    please can we have help from the staf ??
  • LightningHawkZLightningHawkZ Posts: 3
    edited December 2019
    Did this ever get fixed? This is serious issue still happening in Boneworks and H3VR. Changing ports didn't work for me.
  • gramah501gramah501 Posts: 5
    same problem, solutions?
