Headphone problem
RMSkoRMSko Posts: 1
I’m using the SpectraShell OQ9 Oculus Quest earbuds and whenever I disconnect them from my Quest, I have no sound. The only way I can restore the external speaker sound is with a reboot. Also, if I leave the earbuds plugged in, when I take the headset off and then put it on again later I need to unplug and then plug in each side earbud again in order to get headset sound.  Is this normal behavior or is something wrong with my headset?
  • SpuzzumSpuzzum Posts: 843
    Try with just one of the earbuds and see if it continues. I'm using the Vive DAS headstrap with the earphones, plugged into the left jack, and have no problems. Maybe it's a bug having to do with both jacks being used at the same time(?).
