Using x-plane can't control front wheel
Hello, I love my Rift S but on the ground the pedals don't work. in 2D I use Logitech Extreme 3D pro and the twist controls the front wheel and rudder.
Thank you.
Andre
Answers
  • GreymanGreyman Posts: 1,324
    Maybe, for the aircraft you are flying, you need to enable nose wheel steering before you can use your rudders to steer it on the ground.  Open the controls mapping settings and search for "nose wheel" to see if this is the case.
  • andre747andre747 Posts: 3
    thank you for your reply. I am not sure where that is in x-plane but it is on. If I use the joystick it controls the rudder and the nose wheel. are you referring to a mapping inside the rift?
  • TomCgcmfcTomCgcmfc Posts: 2,257 Valuable Player
    In 3d you should be able to use your joystick and control it the same as in 2d.  The touch controllers themselves can be used but right now there is no way to control rudder.  The rudder is kinda coupled to your roll (aileron) axis.  This only works if  you do not have your joystick plugged in.  Otherwise you can use your joystick twist or external pedals for rudder/nose wheel.
    Maybe go go to the Xp11 vr forum for more information and help.
    interesting, I did not think of unplugging the joystick.  Like you said worse case i hold the joystick between my legs and use it for takeoff and landing. Thank you.
  • lensmandavelensmandave Posts: 365
    You can map one of the Touch joysticks to rudder, it's a tad twitchy but it works. :)
    Intel Core i7 6700K @ 4.5GHz. Asus-Z170-PRO MB
    CORSAIR H105 HYDRO CPU COOLER.
    NVIDIA GeForce GTX1080ti. 16GB DDR4 2666MHZ HYPERX SAVAGE.
    SAMSUNG M.2 SSD 128GB SM951 Boot Drive. SAMSUNG SSD 500GB EVO Working Drive.
    Windows 10  64bit Professional
    You can only do this through Steam but like you say it’s not ideal right now.  Hopefully Laminar will properly incorporate this in the xp11 joystick menu sometime soon.
    Not for me. I've never used Steam with X-Plane. Just go into the X-Plane joystick settings menu and select Touch Controllers.
    Simples :)
    edited September 2019
    Did not work with my Laminar download version and cv1 touch controllers.  Also not reported to work well  on the xp11 forum.
    However I have not tried this since 11.30 so maybe I’ll try it again sometime.  Personally I prefer flying with sticks and only use my right touch controller to access menus in VR.
    Yep, running 11.35 here. I prefer HOTAS too (mostly DCS with my Spitfire sim pit) but also enjoy just kicking back in a comfy chair flying X Plane with the Oculus Touch controllers. It gives you an insight into what VR interactive cockpits may be like in a few years :)
  • ddaverutddaverut Posts: 1
    I Had this issue when using zibo 737 mod I had to use the config hardware in avitab and assign steering to yaw not on and works fine
