Rift S does not show boundary when i walk up to and outside them.
AdamChattawayAdamChattaway Posts: 3
I lit just walked into my wall because they did not show. i set them up 3 times now and even made the area smaller to be safer but even when i stick my head out or walk outside the set boundary nothing changed, no wall, warning or change to outside view...
  • uKERuKER Posts: 176
    edited October 2019
    Are you playing with good lighting?
    I suppose you defined the boundaries right.
    Are you sure you have the option to show the walls enabled? (you can select none/boundary/walls)
  • AdamChattawayAdamChattaway Posts: 3
    i shall have a look
