Hi, im trying to set up my Rift S properly so i dont haver to carry my Pc around my flat. I ordered a Usb 3.0 extension Cable (Produced from amazon) wich is working fine. My Problem is the DP cable wich is giving me blackscreens and only sound. When i plug everything in and put the Oculus on my head it renders the grid from the beginning and the 3 Dots loading sign. After that it just turn off and i hear just the loading sound. I have googled a lot Since i got the Headset on wednesday but i havent found a good solution. I hope anyone can help me.
Contact support, I hope they can fix your issue, I am having the same issue with one of my computers, they have not been abel to fix it, I really think is a compatiblity issue but they don't care or try to research more about it, I only kept mine because I can use it on my laptop without a problem.
Yeah they are not really helpful all they suggest summed up is that i replug the cables and restart my pc. I justr bought a new cable wich will arrive next week i think if i get anything to work i will report back.
