Razer Blade 2017 Gtx 1060 compability
Hi!!!
I have a Razer blade 2017 gtx 1060 and i really want to get the Rift S for it, but it has DP port, I just want to ask that if I can buy an adapter to change DP port to Type-C/Thunderbolt 3 and use the Rift ?
Thank u
  • beert.spijkervetbeert.spijkervet Posts: 1
    I have the same issue. Bought an USB-c to display port adapter but it doesn't work. Are there any experiences with the blade gtx 1060 that do work with the Rift s? Thanks for any reaction
