11-25-2019 01:18 PM
11-25-2019 02:20 PM
Quest Link is very finnicky about USB 3 ports, ended up having to connect mine into my front panel 3.1 port that does not have any other devices plugged into that Hub. It works fine for me there.
kenf1071 said:
Any ideas why all my USB ports on both my desktop pcs won't run quest with link ? I get the freezing issue ? but my comp I use upstairs has the 5 port inateck pci -e USB 3/ 5-port Express card which I purchased when I had the cv1 & it works no problem ? My comp downstairs is more powerful so I move the quest back & forward to use on both but I can't understand why it won't work on any of the other USB 3 ports,anyone had those issues & I was trying not to buy another pci card but it's looking like I have no other option
11-25-2019 02:53 PM
11-25-2019 03:55 PM
11-25-2019 04:51 PM
I tried a powered USB 3 Hub in one of my other ports, and it did not work.
Spuzzum said:
I had issues with my mobo's usb ports as well, but flawless with a Startech usb pci-e card. I'm thinking it's the power limit of only 900 mA of the USB 3.0 ports. Maybe a powered USB hub would help.
11-25-2019 06:47 PM
11-26-2019 01:52 AM
11-26-2019 10:50 AM
kenf1071 said:
would we still buy a quest if you knew about all the add ons you would need to buy ? new cables, vr covers, headsraps, controller covers, only certain USB ports work forcing you to buy a usb card to use link ? the quest cost me £399 uk pounds & I’ve probably spent about 100-120 pounds extra to make it comfier or work with link
anyway my new card is coming today along with an extended cable & right angled usb c adaptor so hopefully it all works !!
11-28-2019 11:51 PM
11-29-2019 05:52 AM
