Too much horse power required to run Oculus Link!
iTesla8iTesla8 Posts: 55
edited January 11 in Oculus Quest
Hello
Wanted to share my experience with Oculus Link, have buy i Chinese cable 3m it works everything connects i tested only in Oculus home around 5 minutes the GPU heats allot the fans spin fast and the Oculus home hangs to reset must disconnect/reconnect the USB cable, so you can't stay much there because of this heat issue. Then i have tear down my GPU card and found out after removed the heat sink that the paste is hard ass cement, i took some wool and thinner and cleaned it careful and have apply new paste assembled and put back together, have run the Oculus link now it works no more hang in the Oculus Home but the fans spin very fast and the temp is always 70/71C and stay like this.
Do you people think this is normal? I doubt the integrated GPU of Oculus is better than my PC, i understand it works in a more direct way without Link but still this is awful experience i m afraid my GPU does not burn.
My PC specs are here, though not the latest test: https://www.userbenchmark.com/UserRun/20433679
P.s. i think this is why allot of users have issues because their PC's have low hardware, the PC specs recommended by Oculus Link are too low but in the reality there is needed more.
My Own PC Build: NZXT Source S340 White > Corsair RM1000i > Asus ROG Strix Z270F Gaming > CPU Intel i7-7700K 4.5Ghz > Deepcool Captain120 EX > RAM KHX2400C15/16G | 4pcs = 64GB > Asus GTX1070 Dual O8G > Samsung U32J59xUQ 4K > Realtek High Definition Audio > Intel SSD 760p Series PCIE/NVMe M2.1 1TB > Intel SSD 600p Series PCIE/NVMe M2.2 1TB > AZIO Retro Classic Copper > Razer Mamba Hyperflux = Oculus Quest/Link
  • DaftnDirectDaftnDirect Posts: 5,392 Volunteer Moderator
    edited January 11
    I've edited you post so the link works @iTesla8
    I haven't yet used Link with my Quest as I'm using the Rift-S for PC VR but your specs don't look bad. Interested to hear what other 1070 users' Link experience is.
    Intel 5820K [email protected], Titan X (Maxwell), 16GB Corsair Vengeance DDR4, ASRock X99 Taichi, Samsung 500Gb 960 Evo M.2, Corsair H100i v2 Cooler, Inateck KTU3FR-4P USB 3 card, Windows 10 Pro v1903 (18363.592)
  • iTesla8iTesla8 Posts: 55
    Thank you for that, i also would be interestred what other users say if they have such GPU card.
  • LordZeroGameMasterLordZeroGameMaster Posts: 7
     My laptop is basically the same as his system. I have only tried Skyrim VR that was flawless and Asgard's Wrath that was choppy. It looked fine on my pc monitor but inside the Quest it had kind of microstutters.
     I don't think it was that related to the actual game performance as changing settings all the way to low did nothing to aliviate the sensation of lack of fluidity.
     I played for a good hour and i guess i grew accustomed very quickly, but watching gameplays on youtube, i figured out that it was in fact not as smooth as it should be.
    UserBenchmarks: Game 67%, Desk 70%, Work 50%
    CPU: Intel Core i7-7700HQ - 64.3%
    GPU: Nvidia GTX 1070 (Mobile) - 73.3%
    SSD: Kingston RBU-SNS8152S3256GG6 256GB - 89.2%
    SSD: Kingston A1000 NVMe PCIe M.2 480GB - 134.6%
    RAM: Kingston MSI24D4S7D8MH-16 1x16GB - 41.3%
    MBD: MSI MS-16P1
  • ohgrantohgrant Posts: 253
     I would say by your system, that you should be able to get great results with the link cable with your PC. The one component that is equally as important to Oculus  working as the CPU and GPU,  is the USB controller. I upgraded to a Star Tech 3.1 10 gps USB-C card. You and I have comparable systems I think you'll get it worked out with yours.
    My results
     UserBenchmarks: Game 109%, Desk 85%, Work 90%
    CPU: AMD Ryzen 7 2700X - 83.6%
    GPU: Nvidia GTX 1080-Ti - 134.3%
    SSD:  Micron_1100_MTFDDAK2T0TBN 2TB - 93%
    SSD: SanDisk X400 1TB - 90.6%
    HDD: Seagate Barracuda 1TB (2016) - 98.1%
    RAM: G.SKILL Flare X DDR4 3200 C14 2x8GB - 45.9%
    MBD: Gigabyte GA-AB350-Gaming 3-CF
     One thing that comes to mind with your results was your desktop resolution. 3840 x 2160?  I'm not sure if it will help, but try setting your desktop res to 1920*1080, then try the link.
    Gigabyte  AB350 Ryzen 2700x, 16gb ddr 4 3200, 1080ti. Z800 HMD, DK1, DK2, CV1, Vive wireless, Quest, HP Reverb. Viewsonic 1080p 3D projector ASUS 3D vision monitor. UAD Apollo interface, Yamaha studio monitors.
  • RuneSR2RuneSR2 Posts: 4,299 Valuable Player
    edited January 12
    MBD: MSI MS-16P1
    BTW, the i7-7700HQ is by no means the same as a desktop i7-7700K, the 7700K is much faster:
    https://cpu.userbenchmark.com/Compare/Intel-Core-i7-7700K-vs-Intel-Core-i7-7700HQ/3647vsm211019
    https://www.cpubenchmark.net/compare/Intel-i7-7700HQ-vs-Intel-i7-7700K/2906vs2874
    - and don't think you've got a real GTX 1070 if you got the mobile version - at least according to these results:
    https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1070-Mobile-vs-Nvidia-GTX-1070/m164129vs3609
    I don't think Oculus Link has too high system requirements, but some users may be using way too slow hardware. Personally I'd probably never use a laptop for VR. Just using 3200 MHz ram instead of 2400 MHz increased my cpu speed about 10%, which is really a lot - using a laptop you may not even be using 2400 MHz for the 7700HQ, and it all adds up.
    That said, iff you can run Oculus Link with these very low laptop specs (at least for the cpu), it does seem specs for running Oculus Link may be similar to using Rift-S or CV1 - and not higher.
    If the OP has problems using i7 7700K, GTX 1070 (non-mobile) and 2400 MHz ram, then his rig may suffer from some special/unique problems. The OP should be able to use Oculus Link flawlessly - but it is the beta:
    https://www.roadtovr.com/oculus-quest-pc-requirements-oculus-link-minimum-specs/
  • KoshIrelandKoshIreland Posts: 16
    For anyone seeing choppy playback in Link, but Mirror showing 72fps, then try reducing the pixel density settings: https://forums.oculusvr.com/community/discussion/83561/oculus-link-resolution-with-v12/p1
    It turned my Link from unplayable to consistently smooth (so long as the game itself is running smoothly at 72fps).
    edited January 12
    Hi everyone, thank you very much for your input, i have found out my problem may lay in the cheap USB cable that i have buy from aliexpress also it is 3m long and this is not enough for me, i have ordered another more thick 8m cable it has 2 USB A connectors to 1 USB C conn, hope it will provide the needed power if not will return it back.
    My main problem is i live in a poor country that is why i can't buy original cable, on ebay i found it cost with shipment 200USD that is very expensive for a cable.
    Also i m thinking because i m a technician i can make my own USB cable with proper copper wires and solder them if the chinese cables will not work, and i think for the best experience the cable must be hanging from the top in the room.
    Will post updates what will work for me.
    Thank you!
    P.s. i felt warm from the USB cable but i m not sure if it was the cable or something else.
    Heat in a cable is generally not a good sign. Either means there's a fault, causing overcurrent, or if the current is ok, the cores are undersized.
    I think I'm going to invest in a USB multimeter and start doing some tests. I don't remember seeing figures for headset power consumption, so I'm curious to get some definitive figures. I read somewhere 5W but that sounds low especially if simultaneously charging a low battery. Copper core size would be good to know for various USB cables but I doubt that's listed in specs. Probably could determine by measurement.
    I have tested through a USB dongle but Quest is detect as USB 2 in Oculus software so i can't test in game, it was taking around 2.51W in such state.
    So for sure this cable is poor quality, will have to write in the Link Cable thread again so people don't buy it because i have think it is good.
  • MaxxgoldMaxxgold Posts: 498
    Thank you!
    You don’t have enough power in your USB port for 8m. I’m using a powered Inateck USB card(The one in my signature), and the most I can get is 5.1m. If I add just one more meter I get disconnects. I also have to remove everything from the port except the Quest. Also, the longer your USB cable the less throughput of data will get to the Quest.
    Make sure to post back here, and let us know what happens.
    I found a software that shows what is connected to USB on a Win PC maybe you will find it useful.
    Connected with the 3m poor quality cable that is not recommended to buy.
    I did some testing and the compatibility must meet this 4 criteria not sure i might be wrong on some.
    1. the USB connectors on PC must be proper
    2. the USB cable must be proper
    3. the connected device must support that USB version
    4. the driver/software
    So if something is wrong from one of this criteria it will not work.
    I also have changed display resolution but that does not help, even turned the monitor off it is not related to this.
     Glad you're getting things sorted. Bummer that the link cable cost so much there. Have you checked the Oculus link cable thread, it has other cheaper alternative cables that may work for you.
     Not sure what software you're talking about there, if you're looking for software that will tell you every detail with included diagnostics and benchmarks. It's been around since the Win 98 days formally known as Everest. There's a 30 day free trial here https://www.aida64.com/downloads/latesta64xe
