Recordings including sound & voice
We´ll  be using social apps in Quest for educational purposes and we need to record the interaction for research. The recording option in quest only allows for visual and sound recording and not voice. We need both. Is there a way to solve this? Is the Quest team going to look into this?
Thanks!
  • iTesla8iTesla8 Posts: 107
    This idea would be very useful to record what you speak as you play.
    I did not try to enable the microphone during recording but i have observed when i did in game record there was first the sound then the action it was out of sync for a second or two, this issue should also be addressed.
    My Own PC Build: NZXT Source S340 White > Corsair RM1000i > Asus ROG Strix Z270F Gaming > CPU Intel i7-7700K 4.5Ghz > Deepcool Captain120 EX > RAM KHX2400C15/16G | 4pcs = 64GB > Asus GTX1070 Dual O8G > Samsung U32J59xUQ 4K > Realtek High Definition Audio > Intel SSD 760p Series PCIE/NVMe M2.1 1TB > Intel SSD 600p Series PCIE/NVMe M2.2 1TB > AZIO Retro Classic Copper > Razer Mamba Hyperflux = Oculus Quest/Link
