Magnets in battery cover
In my cv 1 right controller both of the batteries have come out of the cover and now are attached to the controller magnet part. I am able to take on of them out but it doesn't really help because as soon as i get the cover back it goes straight back to being stuck there. This wouldn't be a problem but when ever i do something like in a flick in a game e.g swinging arm in beat saber the cover comes off and the only way to get it back on is to carefully place it back on. is there anything i can do to fix this.
  • adam.poole.313adam.poole.313 Posts: 92
    I can't picture what you are talking about. Did one of the magnets in the controller come loose and get stuck somewhere? If so a stronger magnet might be able to dislodge it. If you are saying something happened to the battery itself then I don't understand... just throw out the battery and use a new one. If there is some broken part stuck in the battery compartment seems you've got to fish it out of there with tweezers. Unless I'm misunderstanding what happened.
  • RichooalRichooal Posts: 1,389
    Can't you super glue the magnet back where it is supposed to be?
    i5 6600k - GTX1060 - 8GB RAM - Rift CV1 + 3 Senors - 0 PROBLEMS
  • sonic2bluesonic2blue Posts: 3
    the broken part is the magnet, it's come loose and now just sits inside of the controller where they lock in to keep the cover on.
    trying thjat now
    @sonic2blue
    How did you go?
