Beta Fix For Oculus Rift Stuttering Issue Released
kevinw729
Honored Visionary
An apparent fix for the widely reported Oculus Rift performance issues introduced by the December update has been released on the Public Test Channel.
https://uploadvr-com.cdn.ampproject.org/v/s/uploadvr.com/rift-v12-stuttering-fix/?amp=&usqp=mq331AQC...
https://vrawards.aixr.org/ "The Out-of-Home Immersive Entertainment Frontier: Expanding Interactive Boundaries in Leisure Facilities" https://www.amazon.co.uk/Out-Home-Immersive-Entertainment-Frontier/dp/1472426959
4 REPLIES 4
Richooal
Consultant
As noted in the PTC sticky on 22/1/20 by ShowbizDonkey
"Update 1/22/2020: Hi all - Dropping by to provide another update
on performance issues that some users have reported. Our engineering
team has been able to identify and implement an update that they believe
will resolve these issues. As our internal testing results have been
positive, we are pushing this fix to the PTC. If you are experiencing
the frame rate drop / performance issue that has been discussed here, we
encourage you to opt into the PTC in order to test out this latest
update. If you experience any issues (performance or otherwise) with
this update, please be sure to utilize the help center > provide
feedback option within the desktop software or open up a ticket with our
support team. Thanks!"
TomCgcmfc
MVP
MVP
Sorry but this beta update did not improve anything for me.  All it did was reintroduce the x plane 11 shutdown bug that was fixed way back with 1.36.  I still feel 1.38/1.39 had better performance than any +12.x version.
I did send oculus my log files yesterday so hopefully this will help.
I’m not really sure but I think the problem is associated with trying to combine the Quest Link into the Rift app.  I think oculus should have made a separate app for the Quest Link and left the Rift app separate/stable.
Anonymous
Not applicable
Fixes nothing for me either.
kevinw729
Honored Visionary
Have to say I am surprised there has not been more discussion about this problem, I know a number of users reverted back to an earlier build to avoid this issue, but this seems kind of serious, but not seeing as much mention.
