01-24-2020 05:52 PM
01-25-2020 05:19 AM
01-25-2020 09:03 AM
01-25-2020 09:50 AM
Hi
I think I have solved it.
First I formatted the pc. (unnecessary)
In addition I have changed the USB port.
But the oculus still remained undetected well and if I now had
the black screen problem.
The definitive solution is
In device manager uninstall the oculus driver.
With the oculus app on and searching for the oculus, disconnect
USB and displayport.
Plug in USB and then displayport.
and it is also very important to disable hybrid shutdown on W10
And restart
Works.
01-25-2020 10:18 AM
01-25-2020 04:42 PM
leklick said:
its rather expensive, do you think upgrading my motherboard or anything else would fix it?
