the problem is that when i launch the OVRserver i receive this error: [DisplayManager] ERROR: No suitable VR display system found which is surprising as the card detected in the DXDiag is : Radeon RX Vega M GL Graphics which is also listed in the compatibility.json as : AMD RX Vega M GL under VideoCardMinSpecList
I've also attached the full list of logs
please help me otherwise i ill have to return the device Many Thanks
I have the same card and same issue. Support has me going in loops of troubleshooting while saying "the card isnt supported" in the same message. its super confusing. like is the card not supported or it is supported and troubleshooting will fix an issue.
Get Help
