Wrong default front direction and sensors location can't be fixed
onyxleeonyxlee Posts: 10
edited February 6 in Oculus Rift S and Rift
Hey guys, I have been stuck in this situation for a long long time. Maybe you can shed some light?
So, my default forward (front) direction in the "reset sensor" setting is totally backwards, and I tried to follow the instruction by pressing a button when facing front has no effect at all, I then tried to reset the guardian area, and noticed this:
While my sensors are actually at the both sides of my monitor, the software thinks they are behind me.
That's why resetting the sensors or guardian never works.
What should I do to fix this issue? Thank you so much!
(I understand that you can reset view in the dash board, but it's just super inconvenient to do it for every app, every time.)
Answers
  • nalex66nalex66 Posts: 5,275 Volunteer Moderator
    If you go through the whole setup process again, it will ask you to point to your front direction. I had this happen recently when unplugging and replugging a sensor—my whole Guardian flipped 180 degrees, and redoing my Guardian didn’t fix it.
  • onyxleeonyxlee Posts: 10
    Thanks, do you mean I need to uninstall and reinstall the whole Oculus driver and rerun the setup from the beginning? Thanks again! :-)
    No, just the full hardware setup part that you do after installing the software. I'm not in front of my VR PC, but there should be an option in the menus to go through the full setup of your Rift.
