Battery low message
huliqanhuliqan Posts: 47
message "Battery low" in right controller
How to disable in game?
In HOME I have full battery,but The message about a low charge constantly pops up and interferes with playing:(((
  • Umpa_PCUmpa_PC Posts: 304
    The funny thing here is thats its the right controller - Mine is always the right controller too.
    Oculus Rift S (love it)
    Oculus Quest 128GB (Loving it too)
    MSI trident 3 7RB-200UK
    Intel Core i5-7400 3 Ghz
    GTX 1050 Ti (4GB)
    16 GB RAM
    1TB HDD
    1TB SSD
    Windows 10 Home Edition Version 10.0.18362 Build 18362
    Oculus app version 14.0.0.83.710 (14.0.0.83.710)
  • huliqanhuliqan Posts: 47
    and? How to disable it? pops up at the most inopportune moment:(((
    And with absolute new battery!!!
    You can't - the only way is to make sure you have a fresh battery before you start
    GTX 1050 Ti (4GB)
    16 GB RAM
    1TB HDD
    1TB SSD
  • BeastyBaiterBeastyBaiter Posts: 807
    What I've noticed is it shows the batteries as full for the controllers until about 5-10 minutes before they die. Then I get the popup message and suddenly they have 1 bar of charge. This is with standard nothing special Energizer and Duracell batteries.
    edited February 14
    Yes, I have been going through batteries.  What I tend to do is swap them out and save them, then stick them in the other controller when it runs out.  I don't like the idea of throwing away half used batteries.  I usually use rechargeable (secondary cells) but I have a lot of primaries left over from Christmas.
    I wonder if we can get some L-ion in the AA package.
    Edit:- yes you can
    https://www.amazon.co.uk/s?k=Kentli+Constant+1.5V+AAA+1180mWh+Lithium-ion+Polymer+Battery+Rechargeable+LiPo+Batteries+%284+Pack+AAA%29&i=electronics&linkCode=gs3&tag=reactual-21
    These might be worth a look.
    GTX 1050 Ti (4GB)
    16 GB RAM
    1TB HDD
    1TB SSD
