Using my Headphones in Oculus Rift doesn't work?
Using the built-in headphones in the Oculus Rift is an issue due to only one ear working, so to try to fix this I unscrewed headphones and tried using my own.
However, this doesn't seem to work as Audio from VR games don't go through to my headphones.
I tried messing with the Audio settings in the Oculus software, but none of it seems to have any effect on this.
If anyone has any idea how to fix it, please help.
  • dburnedburne Posts: 3,219 Valuable Player
    Select your preferred sound device in Windows, you can even make it the default if you wish.
    Don
