Quest Counterbalancing Battery Packs
Doc_OxDoc_Ox Posts: 21
I'm considering purchasing a counterbalancing battery pack for my Quest.  I'm willing to spend a little more to get an off-the-shelf solution, rather than purchasing a battery pack and kludging together a solution.  The two commercial products I can find are:
VR Power:  https://rebuffreality.com/products/vr-power
VRNRGY:  https://www.vrnrgy.com/
Getting a good counterbalance with the Quest headset is my top priority, while the extended battery life is a secondary benefit.  Of course, I also want it to be confortable while wearing it.
Anyone using one of these solutions, or possibly one that I haven't found, and can provide an opinion?  Even better, perhaps you've tried both and can say that one is definitely better than the other?
Thanks!
