I have the latest OTT and Oculus Home. Now when I start up OTT, the Oculus Home flashes on the screen but does not load as it did before. I have to start it up manually. The "Launch Oculus Home on tool start " is enabled and worked fine in previous versions. Also the OTT "sometimes" shuts down 30 seconds or so after loading up without any warning. I'll start it again and it usually works without issue.
Any thoughts, settings to check or ideas as how to solve these little problems. Should I uninstall and reinstall either or both?
