What wireless products do I need to connect Oculus Go to hotel wifi regarded as captive portal
VIPfr
Explorer
I'm staying in a hotel and their Wi-Fi doesn't support the Oculus Go "Initial" set up. What wireless product(s) will be successful in setting the headset up?
5 REPLIES 5
kojack
MVP
MVP
You could try making a hotspot with your phone.
VIPfr
Explorer
Thanks Kojack, I attempted with my Samsung S6 and SJ7 and for whatever reason it didn't work either. Any other suggestions or help is greatly appreciated. Checking out youtube I may have to invest in a range extender "TP AC1900" touch screen router and possibly a laptop. I believe I will need to create a new private network with password to successfully link the Oculus Go onto.
TomCgcmfc
MVP
MVP
I have not been anywhere where my Go has not been able to connect with any WIFI as long as I had the right password.  Sometimes there are restrictions as to what sites they will allow you to go to though, lol!
wuzp
Rising Star
Any low cost travel router from Amazon will do; so long as:
  • It supports one of, or both, 2.4ghz and 5ghz WiFi bands.  5ghz WiFi channels tend to have less interference, and higher bandwidth.
  • The ability to use a wired connection is a "nice to have," as some hotels support, or only offer, wired Internet access.    Wired connections tend to be faster.
  • It supports "captive portal" authentication.  A captive portal is when, after connecting the travel router to an access point, you must then use a web browser (like on your phone) to finish establishing the connection.
  • The capability to switch DNS servers, after establishing a connection; in case the hotel decides to block certain Internet domains; like the one(s) used by your favorite apps/games.
  • A Google search reveals the typical maximum measured WiFi bandwidth of the Quest is about 900mbps.  For maximum "happiness," the travel router should try to support something "close" to this number.
  • A physical size that you can live with; without accidentally leaving it behind, when you checkout.
VIPfr
Explorer
Thanks for your info bro, going to check that out.
