can i play oculusrift library with oculus edge with my pc components.
oculuslovereroculusloverer Posts: 2
HI i have a need for clarity,
i read that oculus edge is able to play occulus rift games through pc.
I believe i read usb3 but im not sure.
would this pc be strong enough(compatible ) to do so ^
896-P3-1255-AR - eVGA GTX 260 CORE 216 55NM 576MHZ 896MB 1.998GHZ GDDR3 PCI-E 2XDVI-I HDTV OUT
P6T DELUXE V2 - ASUS P6T DELUXE V2 S.1366 INT X58/ICH10R ATX 3PCIE X16,6D.DDR3-1600MHZ FSP WIFI-AP GBLAN
CP-850 - ANTEC CP-850 850W CPX FORM ATX12V V2.3 PWR SUP DUAL PCB LAYOUT
BX80601920 - INTEL CORE I7-920 2.66GHZ 8MB CACHE LGA-1366 4.8GT QPI Intel Core i7 920 @ 2.67GHz 50 °C Bloomfield 45nm Technology
HD103UJ - SAMSUNG SPINPOINT F1 HD103UJ 1TB SATA 3G 7200 RPM 32MB CACHE
  • enigma01enigma01 Posts: 826
    edited May 3
    No chance I’m afraid. Your GPU for starts is way off the mark. Your CPU is also ancient and not supported (1st generation i7, generation 10 is due to be released this year!). Your motherboard quoted doesn’t have USB 3.0. You can see Link requirements here https://support.oculus.com/444256562873335/
  • oculuslovereroculusloverer Posts: 2
    edited May 5
    for usb 3 i can put a add on behind . if i change my gpu, what are the chances that it could work?
    question 2 when we say a pc is needed do they mean pc needed to upload rift games in quest hdd ( meaning you can unplug , go the the park and play without pc (
    or do the mean the rift games are only playable through the pc?
