Audio popping/crackling on my rift s
kunio18kunio18 Posts: 23
edited May 17 in Oculus Rift S and Rift
so for some reason i have no idea the sound for my headsets been playing up, it sounds all bitty and scratchy has anyone had this before? im worried that my speakers for it might have broken, the sound in games is scratchy and has bittyness towards sfx
  • Umpa_PCUmpa_PC Posts: 794
    What games are they, and have you tried changing the settings in options or in windows mixer ?
    Windows 10 Home Edition Version 10.0.18363 Build 18363, Oculus version 17, Quest Version 17
  • kunio18kunio18 Posts: 23
    just vr chat fella, and why would that matter, as was fine before as now its started to play up
    edited May 16
    I was thinking if you had some of the sound enhancements on, it could cause distortions with some music thats all.  Mine does it a bit with loud base sounds, but thats because I have boosted the audio.
    i think its my lead, it might be damageed
    Yeah could be, does it do it when you move your head ?
    nah just souned issues man :(
  • HwangPLHwangPL Posts: 4
    I had similar issues but only with microphone. I reconnected usb and it helped.
    any ideas how to fix this>?
    the sounds totally tinny
    ive literally tried everything :(
    do i need to buy a new lead?
    The elephant in the room is - what headset do you have - Rift CV1 or S
    the rift  s mate and im just under the designated stats for vr, all was working fine untill i had crash black screen red light and sound went to pot :(
    Is it under warranty ? if so open a ticket see what O say.
    The only thing I can suggest is try another USB port - but I would imagine you have already tried that.
    i have tried everything and i dont think it is as i got it from pc world
    i need to buy a new cable whenver they come in stock ever again :(
    edited May 24
    Yes but the warranty is with Oculus, and I think its two years !
    How Long Does Coverage Last? This limited Warranty continues for one (1) year from the date of purchase or delivery of the Product, whichever is later (the “Warranty Period”). However, if you purchase the Product from within the EU or EFTA, the Warranty Period shall be two (2) years.
    https://scontent-lhr8-1.xx.fbcdn.net/v/t39.2365-6/49630950_615501395581577_8065528336517955584_n.pdf?_nc_cat=107&_nc_sid=ad8a9d&_nc_oc=AQnnD7ON2OSNO8KtdiqkaqO7lC-h8f1zOs7jyzadPWFTwOJIbyGgMXx72u-ZXaElqxY&_nc_ht=scontent-lhr8-1.xx&oh=e8e66ea6a09c1f4a12aa26333e7adaf4&oe=5EF03930
  • ErkkipenapetteriErkkipenapetteri Posts: 7
    I've had on/off popping/crackling on my CV1 since forever. It comes and goes with software updates. From what I've gathered it can be an issue with USB. If you switch around where you've connected your gear, the issue may disappear (or not).
    so get a full refund from pc world uk when it re open?s
    Being under warranty does not entitle you to a refund.  How long have you had it.
    Open a support ticket - talk to Oculus; and they might send a replacement.
    I would imaging PCWorld will tell you to contact Oculus anyway.
    i have had my rift s since january and im really thinking of sending it back, its cause me so much grief in the last month since a new update from the software nothing seems to work :(
