Unit crashes, battery life less than 90 min
QBeyesQBeyes Posts: 2
I have had this unit for less than a week.  At least a dozen times, it suddenly goes black and can only be brought back to life by restarting it.  Also the battery last less than 90 minutes.  Would returning it for a replacement solve these issues?
  • TomCgcmfcTomCgcmfc Posts: 2,158 Valuable Player
    No, 90 minutes seems about right.  If you want longer runtimes you can either connect the supplied charger to it while playing or use an external battery pack.  I use an inexpensive 10000mah pack and this can easily add a few hours runtime.
    Custom built gaming desktop; i9 9900k (water cooled) oc to 5ghz, gtx 1080 ti, 32 gb 3000hz ram, 1 tb ssd, 4 tb hdd.  Asus  ROG Maximus xi hero wifi mb, StarTech 4 port/4 controller sata powered usb3.0 pcie card, Asus VG248QE 1080p 144hz gaming monitor, Oculus Rift cv1 w/2x sensors, Vive Pro w/2.0 base stations/controllers, Quest w/Link and VD wireless (good/close 5Ghz wifi and PC with Ethernet cable to my Router).
  • QBeyesQBeyes Posts: 2
    Thanks for that, I have discovered that work around but the crashes make me think my unit may be defective.
    If you think it's a problem contact Oculus Support and start a ticket.  They are usually very helpful.  One thing they may suggest to you is to fully charge it up and do a factory reset, then set it all up again.  Refer to the top sticky on this Go subforum.  Good luck mate.
