rift s replacement cable restock ?
wuzzyize
Honored Guest
my cable is broken and i need a new one... badly 😐
McNutts
Adventurer
I was told by support that they will probably be back in stock on the website in the future but right now they don't have any just for sale. But since your's broke I would contact support by opening a support ticket. Explain your problem as detailed as you can and hopefully they can help you out.
I can't imagine Oculus doesn't have any replacement cables for people that need them because of issues like this or some other problem covered under the warranty.
URL For Opening a Support Ticket: https://support.oculus.com/885981024820727/
Ryzen 7 5800X | 3090FE | 32GB@3600MHz | Rift S | 128GB Quest1 | 256GB Quest2 | 64GB Go | PSVR | Index
