06-05-2020 07:34 PM
06-06-2020 09:50 AM
06-07-2020 12:35 AM
Django-OS said:
Hi! Several reasons are possible......
Because your Link is working, have a look on your Quest battery!
Most USB ports don't deliver the required Amps (only 0,9A). So when battery gets down Link could not work.
BTW:
Cable tests.. YES, I had the same problems (as all other have or had). And I can tell that it is not only the cable that produces bad links. Using the original Oculus cable my USB-C on RTX card don't work, my onboard AMD chipset (X570-pro) also don't work.
I only get Link working with an old ASM1142 chipset (additional card, only 1.5 Gbs)
Hope that helps
06-07-2020 03:54 PM
BTW:
Hope that helps
06-08-2020 06:55 AM
