Difference between Quest and RIft S controllers?
McNuttsMcNutts Posts: 81
I own a Quest and a Rift S and use them a lot. I am thinking of buying a backup set of touch controllers so I have some ready to go in case I break a controller or if the controllers start to go out. I always have a backup controller for my devices. I have one for my Xbox One X and my PS4 Pro. They are sitting in their boxes waiting to go in case I ever have an issue with the one I'm using now.
What I want to know is that is there a difference between the controllers that are sold on the Quest accessories page and the Rift S accessories page?
If the controllers work for both headsets I'm probably going to buy them today. If they don't work for either headset then I will probably wait a little bit. $140 for a set of controllers for both headsets I can swallow. $280 for a set for each headset is a tough pill to swallow.
Main PC: AMD Ryzen 7 3800x @ 4.5GHz all cores | Noctua NH-D15S with 2 Fans | GIGABYTE X570 AORUS ULTRA |  32GB [email protected] | EVGA 2080 Super XC Ultra | OS(Win 10 Pro) - 250GB NVMe WD Black | Games - 1TB NVMe Samsung 970 EVO Plus | 4TB Seagate Barracuda | Case - NZXT H510i | PSU - CORSAIR RMx Series 850W Gold |
Plex Server: [email protected] | 16GB | 250GB SSD | 2x4TB WD Black HDs | EVGA 980 ti
VR Headsets: Rift S | 128GB Quest | 64GB Go | PSVR | Valve Index after 8-100 weeks
  • DaftnDirectDaftnDirect Posts: 5,802 Volunteer Moderator
    They're the same controllers, I have both headsets and either set of controllers can be paired with either headset.
    Intel 5820K [email protected], Titan X (Maxwell), 16GB Corsair Vengeance DDR4, ASRock X99 Taichi, Samsung 500Gb 960 Evo M.2, Corsair H100i v2 Cooler, Inateck KTU3FR-4P USB 3 card, Windows 10 Pro v2004 (19041.330)
  • McNuttsMcNutts Posts: 81
    edited July 2
    Thanks for the reply. As soon as the left hand controller comes back in stop I'm going to order them both.
