Old visual interface for shutting down/restart and charging while shut down
aguy10aguy10 Posts: 7
I changed my password for my Oculus account. After the headset updated it looks like it started using old interface screens for shutting down and displaying the charge when the machine is off plugged in. This doesn't seem to have affected the performance as far as I can tell yet. I've already done a factory reset and the cleaner looking modern interface doesn't come back.
Just wondering you people's thoughts on this. Thanks.
  • TomCgcmfcTomCgcmfc Posts: 2,412 Valuable Player
    Maybe it will come back with the next update (v20).  Also check your dashboard/setting/all/about and see if another update is available.  You can also see what version you are currently on (should be V19).  I guess as long as it's working ok and you can access everything I would not worry about it.
  • aguy10aguy10 Posts: 7
    edited July 26
    Where it says version and runtime version both says 18. Above it where it says software update it says no updates available even though I'm connected to Wi-Fi.
