Oculus rift s cameras turn static
AcubenssAcubenss Posts: 2
My oculus rift s cameras turn static after a little time of playing usually after a few minutes but somtimes longer
This completly disables any tracking so i cant move my hands in game
I've tried a few things
-Tried all the usb ports on my computer
-Reinstalled oculus software
-Tried oculus beta option It turns static with the option on and off
-Factory reset my pc
-Put my power saving on high performance
-Put usb power saving off
If anyone knows how to fix this issue please tell me
PC specs are
AMD ryzen 2600x
Geforce 1060 6gb
16gb ram clocked at 3200mhz
Asus TUF b450 motherboard
  • dburnedburne Posts: 3,758 Valuable Player
    Did you go into device manager in Windows and disable power management for all your USB devices?
    I know you said you put power saver off for USB, just checking you did them individually?
    Don
  • ao1977ao1977 Posts: 10
    Had the same issue twice during the last days, and it definitely came with the latest software update.
  • Freejack77Freejack77 Posts: 3
    Have that too, usually once a day after some time playing. I stopped using the OTT and the last 3 days where fine. But this can also be coincidence.
  • OculusSupportOculusSupport Posts: 895 Oculus Staff
    Hey @Acubenss can you try removing other USB devices as well? If the issue persists, can you gather your diagnostic logs with the steps here, and create a ticket here so that we can look into assisting further. - Principe
  • AcubenssAcubenss Posts: 2
    @dburne Just checked the settings, all of the usb power saving settings are set to off
