Rift s keeps losing tracking and blacking out need help
OwO696OwO696 Posts: 2
Rift s I's fine for 10-25 minutes then It usually blacks out and after that my headset and controllers lose tracking every 2-6 minutes
  • MushroomiesMushroomies Posts: 200
    Need more info, What are you connected to, What GPU and Computer, Have you tried a different USB Port?
  • ZaccSmacc921ZaccSmacc921 Posts: 2
    I had the same prob on my quest using link but then it just stopped after I took a break for like an hr
  • OwO696OwO696 Posts: 2
    My specs are Cpu Intel i3-4150  Gpu Gtx 980  Memory 8 gig and yes I have tried all the usb 3.0 ports on my computer
  • TomCgcmfcTomCgcmfc Posts: 2,445 Valuable Player
    Maybe contact Oculus Support and ask them.  Could be a Cable issue and or maybe just because your PC is just below spec, who knows?  Also, if you just did a Win10 feature update go to your device manager and make sure all your usb ports have power savings disabled (unchecked).  Good luck mate.
