i need help with my link
poomasteryaypoomasteryay Posts: 8
so i go on oculus home on my pc and i go to devices. then i plug the link in. i get nothing, im getting desparet plz help i have tried public test channel but it just doesnt detect the quest it keeps on doing the little swirly thing above the picture of the link so. if someone could help me with it i could never repay you. -ps if you help me i thank you sincereley
  • RichooalRichooal Posts: 1,802 Valuable Player
    Read through the info at the link. Follow it step by step.
    https://support.oculus.com/525406631321134/#setup
    i5 6600k - GTX1060 - 8GB RAM - Rift CV1 + 3 Senors - 0 PROBLEMS 1 minor problem
  • poomasteryaypoomasteryay Posts: 8
    @richooal everythings good
    but it still doesnt work
    oh wait
    what if your prossesors an i3 8100
    Processor Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz, 3600 Mhz, 4 Core(s), 4 Logical Processor(s)
    and what are the minimum requirments for link
    If you read the info on the link I posted for you, there is a link for you to click on that tells you what the requirements are.
    Go through it "step by step"
