Rift S will not connect through the display port and the USB 3.0 port
I have tried many times to connect my rift s to my computer and it wont notice that its plugged in. I have even clean the ports out and tried again, still nothing. I have also tried what was on the website to try and make it work and that didn't  work.
  • RichooalRichooal Posts: 1,959 Valuable Player
    As always, if you want help or suggestions, you need to give information. We can't guess what your computer is.
    i5 6600k - GTX1060 - 8GB RAM - Rift CV1 + 3 Senors - 0 PROBLEMS 1 minor problem
  • Shooter1999Shooter1999 Posts: 3
    i5 2500K, GeForce GTX 960, 8GB Ram, Rift S. I am sure the graphics card is to low but should that really matter? I'm new to the VR experience and not real inclined about computers. thanks for the feedback
    Your GTX 960 is minimum requirement, but you CPU is slower than the minimum CPU required.
    So, you've installed the Oculus setup ok?
    What part of the setup do you get to and what is the error message or problem you get?
    It gets to the headset sensor check and just loads for ages but never connects. I tried it on my brothers computer and it loaded up and worked perfectly so I think it is my computer that's the problem.
  • camf33camf33 Posts: 4
    edited November 16
    It could be a problem with your MB chipset drivers, even OS, or even hardware.  To tackle this you can go about in so many ways but if you are not used to performing more advanced troubleshooting techniques I would advise you to be careful.
